Campus Switching and Routing
Aruba S1500 MAS - Flash Device Not Ready Error on Boot and CPBoot CLI
Hi All,
I'm putting together a wireless lab and having some problems with the MAS switches.  I've configured and built AP's, a 7010 controller, and other devices, but the S1500 switches are giving me problems.
These two switches I have received from the same Ebay vendor are having the same problem.  So I need to figure out if I can fix the problems or return the switches.
Is there any removable storage on these devices or something that could be missing after a factory restore?  I had one open and there doesn't seem to be a place for removable storage.
Here is the error I get on boot and the error I get when trying to do an upgrade in CPboot mode.
CPBoot 1.0.46.0 (build 43231)
Built: 2014-04-15 at 10:35:41
1024MB DRAM init, XLS CPU, 64bit channel pair mode
DDR2 DRAM running at 533Mhz
DRAM:  Total = (0x40000000) 1024 MB
POST:  Memory test: Physical 0x00000000 - 0x10000000 - quick test
      Memory test: Physical 0x10000000 - 0x40000000 - quick test
      PASS
CPU:   XLS208, rev. A1 Clock: 750MHz
CPLD:  rev: 1.8 (0x1.8)
SMP:   All 8 cpus successfully started
Board: S1500-12P
PCIE:  RCx4 mode
Inven: primary inventory is OK
POST2: System Voltages
      PASS
PCIE0: Link Up. (PhyUp=1 DatLnkUp=1 PwrMode=0 LtssmState=17)
      Aruba DPE (PCIE-DevId 0xDF7C)
      BAR1(64M) @ 0xC0000000 (phys 0x60000000)
      BAR0( 1M) @ 0xC4000000 (phys 0x64000000)
PoE:   OK - Ports remain disabled
Net:   xls_gmac0 [PRIME], xls_gmac1, xls_gmac2, xls_gmac3
Boot:  Primary bootflash partition
Reboot code: 8:b3:22:29:27
Hit any key to stop autoboot:  0
booting system partition 0:0
USB:   USB 2.0 started, EHCI 1.00scanning bus for devices... 2 USB Device(s) found
      scanning bus for storage devices... Device NOT ready
  Request Sense returned 02 3A 00
max USB Storage Device reached: 1 stopping
1 Storage Device(s) found
Device NOT ready
0 blocks read: ERROR
0: Partition not created
Device NOT ready
Image not present
booting system partition 0:1
Device NOT ready
1: Partition not created
Device NOT ready
Image not present
booting system partition 0:2
Device NOT ready
2: Partition not created
Device NOT ready
Image not present
booting system partition 1:0
Image not present
booting system partition 1:1
Image not present
booting system partition 1:2
Image not present
cpboot> pfe mgmt
UPLINK_PRESENT_L  = 0
UPLINK_POWER_GOOD = 0
CPLD settings: Bobcats out of reset (POE enable not changed)
CPLD settings: Phy out of reset (POE reset not changed)
Phy Led Blink
pcie0stat = 17 (DPE near power supply )
pcie1stat =  0 (DPE near Uplink       )
pcie2stat =  0 (device on Uplink board)
CPLD Board Id = 14
Autodetected Cointreau12 based on PCIE link status
List of registered PCI devices
Vendor 11AB Device DF7C on bus 1
Bobcat autoinit
pci read 0xc0000050 [vendor_id]...= 000011AB (expecting 0x00011AB)
Bobcat 0 speed 222245640
Detecting uplink:
MarvellXphy   = 0
MarvellCub    = 0
MarvellBobcat = 0
MarvellSolaia = 0
PCI3_FPGA     = 0
Uplink=Direct SFP
Start bobcat(s) configuration
Configure Cpu GMAC1 PHY
Configure Cpu GMAC2 PHY
End bobcat(s) configure
configured the front panel port 0 as managment port
cpboot> saveenv
Saving Environment to Flash...
Erasing ##
Erased 2 sectors
Writing ################
cpboot> printenv
bootargs=quiet
bootcmd=bootf
bootdelay=5
baudrate=9600
loadaddr=0x87000000
bootfile=vmlinux.strip
psb_os_cpu_mask=0
userapp_cpu_map=0x0f
eth6addr=00:0b:86:99:47:42
eth7addr=00:0b:86:99:46:42
ethprime=xls_gmac0
ipaddr=192.168.2.133
netmask=255.255.255.0
serverip=192.168.2.12
gatewayip=192.168.2.254
boardname=cointreau
mgmt_port=0
netretry=no
ethaddr=00:0b:86:92:41:b8
eth1addr=00:0b:86:92:41:b9
eth2addr=00:0b:86:92:41:ba
eth3addr=00:0b:86:92:41:bb
eth4addr=00:0b:86:92:41:bc
eth5addr=00:0b:86:92:41:bd
stdin=serial
stdout=serial
stderr=serial
ethact=xls_gmac0
Environment size: 562/131068 bytes
cpboot> ping 192.168.2.12
Using xls_gmac0 device
host 192.168.2.12 is alive
cpboot> upgrade 0:0 ArubaOS_MAS_7.4.1.9_62608
0: Device not present
