Campus Switching and Routing
Aruba S3500-24P * Safe to use a 350Watt PSU if no PoE usage?
First, I am new to this board, so I hope I posted in correct place.
Long story but I am about to be gifted a used Aruba S3500-24P enterprise-grade Switch; including the 4-port 10GB Module.
It would be for home use, mostly for its 10GB ports.
The Aruba S3500-24P is a PoE Switch; and per the specs, normally comes with a 600watt or 1200watt PSU.
** I will not be using the PoE feature at all.
I can obtain from someone else, a 350watt PSU; but do not know if safe to use.
Question: if PoE is not being used on a Aruba S3500-24P, can a 350watt PSU be used?
Thank you
