Campus Switching and Routing
Aruba s2500 access switch
Hi, can someone please help me the the mobility access s2500 switch. we currently bought a new access s2500 switch and I`m unable to access it via web gui. I followed the required steps of enabling web gui under maintanance and it does not help. The client ip address is on  the same subnet  as switch and when I try to login using the switch ip address it prompt me with the login page but when I enter admin and password it does not show anything.
Re: Aruba s2500 access switch
Hi Joshua,
I have couple of questions:
1. Did you try logging in using different browser ?
2. Are you able to SSH in to the switch & login via putty,teraterm etc?
In case you have console access to the switch, please attach the following output :
1. Aruba# show port status
2. Aruba# show user
Thanks a lot. Upgrading the firmware solved the issue.
