Campus Switching and Routing
Aruba with Cisco trunk issue
I have 2920 sw and using  direct with cisco router 800 series.
for user we are using cisco switch which is conecting with Aruba 2920
when making TRUNK its take only one VLAN,i need 3 VLAN working with cisco switch.
Re: Aruba with Cisco trunk issue
What is your config on both sides?
Jibran Aziz
CCIE (RnS / SP / DC) , ACDX , ACCP , ACMP
Dear check below both sw conf
when i am trying to internal routing in aruba its not taking only 1 vlan is wee can do remotly access.
2 Trunk also not taking all vlan only 1 vlan taking in aruba.
cisco switch conf
__________________
hostname switch0a0a15
ip ssh pubkey-auth
ip telnet server
interface vlan 1
ip address 192.168.30.4 255.255.255.0
no ip address dhcp
interface vlan 23
name Servers
interface vlan 150
name WIRELESS
interface gigabitethernet1
switchport mode access
switchport access vlan 150
interface gigabitethernet27
switchport trunk allowed vlan add 23,30,150
interface gigabitethernet28
___________________________________________
aruba sw conf
Edge-Sw#
Edge-Sw#
Edge-Sw# sh run
Running configuration:
; hpStack_WB Configuration Editor; Created on release #WB.15.17.0009
; Ver #07:eb.8f.fc.f3.ff.37.2d:89
stacking
   member 1 type "J9729A" mac-address e0071b-e2e440
   member 2 type "J9729A" mac-address e0071b-e61700
   member 2 priority 192
   exit
hostname Edge-Sw"
trunk 1/48,2/48 trk1 trunk
trunk 1/46-1/47 trk2 lacp
ip default-gateway 192.168.30.1
ip route 0.0.0.0 0.0.0.0 192.168.30.1
ip routing
snmp-server community "public" unrestricted
oobm
   ip address dhcp-bootp
   member 1
      exit
   member 2
      exit
   exit
vlan 1
   name "DEFAULT_VLAN"
   no untagged 1/1-1/10,1/13-1/30,1/38,1/45,2/1,Trk1-Trk2
   untagged
 1/11-1/12,1/31-1/37,1/39-1/44,1/A1-1/A2,1/B1-1/B2,2/2-2/47,2/A1-2/A2,2/B1-2/B2
   no ip address
   exit
vlan 11
   name "Users"
   untagged 1/2,Trk2
   ip address 192.168.11.1 255.255.255.0
   dhcp-server
   exit
vlan 23
   name "Servers"
   untagged 1/4-1/10
   ip address 172.23.23.1 255.255.255.0
   dhcp-server
   exit
vlan 30
   name "Data"
   untagged 1/1,1/3,1/13-1/24,1/38,1/45
   tagged Trk1
   ip address 192.168.30.2 255.255.255.0
   exit
vlan 150
   name "Wireless"
   untagged 1/25-1/30,2/1
   tagged Trk1
   ip address 192.168.150.2 255.255.255.0
   exit
spanning-tree Trk1 priority 4
spanning-tree Trk2 priority 4
dhcp-server pool "Users"
   default-router "192.168.11.1"
   dns-server "199.85.127.19"
   network 192.168.11.0 255.255.255.0
   range 192.168.11.10 192.168.11.200
   exit
dhcp-server pool "severs"
   default-router "172.23.23.1"
   network 172.23.23.0 255.255.255.0
   range 172.23.23.10 172.23.23.200
   exit
dhcp-server enable
Contributor I
You seem to mix up Cisco VLAN trunking (multiple VLANs on a port) with ArubaOS-switch port trunking (bundling mutiple ports together). The attached PDF file with some examples should help.
Contributor I
In ArubaOS trunk means link aggregation using LACP.
If you want to configure a dot1q port you shoud tag vlans to a port:
int 2
 tagged vlan 23
 tagged vlan 30
 tagged vlan 150
 untagged vlan XX (usually you untag the root vlan from the trunk)
If it helps please add Kudos
