Campus Switching and Routing
Frequent Contributor I
ArubaOS REST API for DHCP snooping
So I have started taking a look at REST API for managing our switches (2530, 2540 and 2930), and yesterday I did some tests retrieving DHCP snooping config from a couple of switches. But it looks like only part of the config is currently supported by REST. When I ran the GET command I only received Authorized Server-1 and Authorized Server-2 as response. What about the other authorized servers, trusted port settings, database settings etc? I took a look in the schema file Dsnoop.json, and it was the same there.
Re: ArubaOS REST API for DHCP snooping
You are right. Currently this is limited for 2 Autherized servers and its planned to fix towards the year end.
