Campus Switching and Routing
ArubaVPN with MAS and alerting when the tunnel is down
Maybe i simply missed this somewhere but how can I be alerted when a VPN tunnel between a MAS and a controller is offline using Airwave?
I will be relying on this alert to proactively investigate issues.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Re: ArubaVPN with MAS and alerting when the tunnel is down
Do you have syslog being sent to AirWave? You can create an alert trigger that keys off the relevant log text.
Tim
Tim Cappalli | Aruba Security
Not currently since Airwave does not sit behind the tunnel, it will have to go to a public IP for that. Shouldn’t be an issue. Simply send logging to <public_ip>
Add the switch using port forwarding rules from the public side or maybe I can key off the controller logs?
Airwave is at our DC, MAS is at the dealership and WLC is at customers DC.
ACDX #420 | ACCA
So I got this to work finally.
the MAS generates the following syslog message
Dec 17 17:43:29 :217002:  <WARN> |l3m|  Vlan interface _aruba-vpn link state down
I then made sure my MAS was sending syslog message to my Airwave by typing
conf t
logging <Airwave_IP>
exit
wr me
On Airwave, in System -> Syslog & traps, if I filter by my device or just search for
_aruba-vpn
 You will see the following:
At this point you create a trigger that matches the device event with the contents of the syslog message and send an email to yourself.
You then get the alert in Airwave
You will then receive the email as well:
Device Event: Event Contents matches Vlan interface _aruba-vpn link state down and Event Type is Syslog
Severity: Critical
Time: Thu Dec 17 17:45:17 2015
Notes: VPN DOWN!!!!
Device: HON-ON-MAR-00001-SW1 - https://wlan-aw-1.c6.dv/ap_monitoring?id=15421
Group: Canada
Folder: Top > Canada > HON-ON-MAR-00001 > Switch
Alert Time: 2015-12-17T17:45:16-05:00
Message: Dec 17 17:43:29 HON-ON-MAR-00001-SW1:PRI-0 l3m[1567]: <217002> <WARN> |l3m|  Vlan interface _aruba-vpn link state down
Bingo Bango
ACDX #420 | ACCA
