Campus Switching and Routing
Occasional Contributor I
Auto Backup config
Hi.
Is there a way to automatically save the config on a tftp server on the Aruba switches just like the Cisco ones?
Cisco uses the archive command to save automatically everytime the config gets saved.
Thank you
Re: Auto Backup config
There is no command like the archive command, unfortunately.
Colin Joseph
Aruba Customer Engineering
Thank you
hi, maybe you already know this but you can use jobs:
job testBackup-runningconfig at 20:00 config-save "copy run tftp 10.0.0.1 Backup-switchname.txt"
Maybe you find this helpfull.
