Campus Switching and Routing
BPDU Guard snmp trap
Do  guys you know if the  aruba os switch sends any sort of snmp trap when that event happens
I mean when a switch connects to a port fast that has bpdu guard enable and send me a trap that he turned off the port becuase someone tried to connect a swtich on a port fast port.
Cheers
Carlos
Alternetworks Corp
Contributor I
Re: BPDU Guard snmp trap
On ArubaOS-Switches this feature is called bpdu-protection. Here is how you configure it incl. enabling SNMP TRAPS:
ProCurve Switch 5406zl(config)# spanning-tree <port-id> bpdu-protection
ProCurve Switch 5406zl(config)# spanning-tree trap errant-bpdu
