Campus Switching and Routing
Contributor I
Blocked by STP
Good morning everyone! A pleasure to greet you.
I currently have a 7205 Controller (version 6.4.3) to an HPE 5400 Switch (version K.15.16.0006), optical ports (10GE), Trunk (L2), allowing only specific VLANs.
You only have one link between the Controller and the Switch. The default configuration is left on the Controller, ie the port with STP enabled (point-to-point). SWP (Provision) has STP (RSTP) enabled.
However the STP blocks the port where the Controller is connected and boots all the traffic. In order to restore it, a CLI reload is performed to the Controller.
Measures taken:
1. Disable the STP for the port on the Controller
2. In the SW, the port was instructed to stop sending and receiving BPDU (spanning-tree ethernet a1 bpdu-filter).
In that scenario, the incident was repeated.
3. STP was enabled on both computers, certifying that it was point-to-point in both end.
And the problem persists.
I appreciate your comments.
Re: Blocked by STP
STP should be disabled globally on the controller to allow the HP switch to do loop detection.
Config t
No spanning-tree
Contributor I
Re: Blocked by STP
I have disabled STP globally, I will have it in monitoring.
I'll let you know how it goes in the next few days.
Thanks Collin
Contributor I
Re: Blocked by STP
Hi Collin
The problem still persists.
I have detected in the log of the Switch that the STP blocked the port, yesterday.
SW-CORE-E1# show logging -r | i A8
I 07/06/17 12:24:12 00076 ports: port A8 is now on-line
I 07/06/17 12:24:10 00435 ports: port A8 is Blocked by STP
I 07/06/17 12:24:09 00077 ports: port A8 is now off-line
I 07/06/17 12:24:08 00435 ports: port A8 is Blocked by STP
I 07/06/17 12:21:12 00077 ports: port A8 is now off-line
Contributor I
Re: Blocked by STP
Hi Collin
I still continue with STP problems.
The controller is globally disabled and in the port.
In the SW-HPE-5400, the AUTO-EDGE-PORT was disabled and the ADMIN-EDGE-PORT was enabled.
show spanning-tree config
Multiple Spanning Tree (MST) Configuration Information
STP Enabled [No] : Yes
Force Version [MSTP-operation] : RSTP-operation
Default Path Costs [802.1t] : 802.1t
Port State Events Logging : Disabled
MST Configuration Name : 10604bc38300
MST Configuration Revision : 0 Switch Priority : 4096
Forward Delay [15] : 15 Hello Time [2] : 2
Max Age [20] : 20 Max Hops [20] : 20
| Path Prio Admin Auto Admin Hello Root TCN Loop BPDU
Port Type | Cost rity Edge Edge PtP Time Grd Grd Grd Flt
A1 SFP+SR | Auto 128 No Yes True Global No No No No
A8 SFP+SR | Auto 128 Yes No True Global No No No No
