Campus Switching and Routing
Can someone point me to a guide to connect 3 210's to a Cisco 2960 switch
I have three aruba WAPs connected to a Cisco 2960 switch. what i want is that each WAP supports 5 networks like this:
Company One guest VLAN (vlan 200)
Company One inside VLAN (vlan (201)
Company Two guest VLAN (vlan 202)
Company Two inside VLAN (vlan 203)
Plus a management VLAN. (vlan 2)
i have no guide and would love some help getting this setup.
Re: Can someone point me to a guide to connect 3 210's to a Cisco 2960 switch
Is this an IAP ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
It is a Aruba 210 Wireless Access Point, not sure what IAP is.
they are IAP-210 Series Wireless Access Points
Is that is the case you need to do the following :
On the switch interface that you will connect each IAP
interface gig 0/1
switchport trunk encapsulation dot1q
switchport mode trunk
switchport trunk allow vlan 200-203
switchport trunk native vlan 2
On the IAP
Create a new Wired Setup:
Then click next and finish
Thank you
Victor Fabian
thank you so very much!
