Campus Switching and Routing
Re: Captive portal on local controller not wokring
You should at least be able to do an NSLOOKUP to www.yahoo.com on that client.  Can you do that?
Contributor I
Yes from that client, i can nslookup the domain www.yahoo.com
Thank you, so dns is wokring fine, what is the next step?
Lee
Can you do an nslookup to securelogin.arubanetworks.com?
Contributor I
No, it cannot know securelogin.arubanetworks.com
DNS server of Guest network is 8.8.8.8, so it i's dont know what is securelogin.arubanetworks.com
Thnk you
When you have a captive portal WLAN, the controller should intercept any DNS traffic to securelogin.arubanetworks.com and return the ip address of the controller.  Did you change the Captive Portal Certificate on the controller?
The resolution to the issue ended up being the filename to the HTML page uploaded did not match what was configured in the Captive Portal Authentication Profile.  The filename to the HTML is case-sensitve..
Contributor I
Thank you Colin,
Thank for your time to help us resolved proplem.
Thank so much
lee
