Campus Switching and Routing
Occasional Contributor I
Change Mask on a default vlan of routing HP5700
I'm going to explain clearly :)
I have 2 HP5700 in a stack routing several network. The network of production has a mask /24 and my customer wants to change it to /23.
I want to know if i must shutdown the interface to change it OR not.
I have several Bridge-Aggregation
Here is the configuration.
Nicolas
interface NULL0
interface Vlan-interface1
description L3 interface BUREAUTIQUE
ip address 192.168.254.254 255.255.255.0
interface Vlan-interface10
description EXTERNAL
ip address 10.0.0.2 255.255.255.248
interface Vlan-interface120
description L3 interface POSTPROD
ip address 192.168.1.7 255.255.255.0
dhcp relay server-address 192.168.254.80
dhcp relay server-address 192.168.254.81
interface Vlan-interface121
description L3 interface DALET
ip address 192.168.121.1 255.255.255.0
interface Vlan-interface123
description reserve
shutdown
