Campus Switching and Routing
Command for history interface
Is there a command to show how long a interface hasn't been used?
If i do a show int i can see which interfaces have used 0 bytes, but is there a way to get some timestamp/frame?
Re: Command for history interface
show port link-event will show you how many times a port has gone up or down, but there is nothing to say when was the last time there was traffic.
