Campus Switching and Routing
Compatibility Aruba and Juniper EX Switches
having a client investigating to deploy Juniper EX switches (4300 Series) in the campus core and Aruba (2930F) in the access layer.  Juniper EX mostly because of the VRF-support.
Anybody having experience in the compatibility of those devices / vendors especially when using VSF on Aruba and VC (Virtual Chassis) on Juniper?
Many Thanks!
Occasional Contributor I
Re: Compatibility Aruba and Juniper EX Switches
VSF on the 2930F is stacking. There should be no issues with whatever is upstream of the stack.
VRF is a logical separation of L3 functions in a switch so, if the uplinks are mapped to the appropriate VRF instances, it should be fine.
Net net is that VSF and VRF are not "competing" against each other and serve a different purpose. There should be no issues interoperating
Hi seth_cse_nh,
many thanks for your feedback.
I probably missed some important information in my question ...
The setup will be a VSF-Stack with multiple Aruba 2930F connected using LACP links to two Juniper switches in a Virtual Chassis.  Meaning the LACP Trunk will spread across multiple Aruba and Juniper devices.
I think it should work, but still wanted to check.
Michael
You could have a look at the Aruba 8400/8320 campus core switches as well for this purpose.
