Campus Switching and Routing
Compatibility issue regarding PD-3501G-AC PoE Injector and AP-215
I would like to ask regarding the compatibility issue of PD-3501G-AC  PoE Injector and AP-215. As per the data sheet PD-3501G-AC  maximum power output is 16.8W and the AP-215 power requirement is 19.6W. Although the AP can be power up by the PoE injector, can it support the AP for a long period of time?
Re: Compatibility issue regarding PD-3501G-AC PoE Injector and AP-215
The PD-3501G-AC is conforming to 802.1af, standard PoE that can deliver 15.4W at the powered device.
The AP-215 is fully compatible with standard PoE, however will disable the USB port if on standard PoE. From the AP-215 specifications (
Power over Ethernet: 48 Vdc (nominal) 802.3af/802.3at compliant source
  • USB port is disabled when using an 802.3af PoE power source; for unrestricted operation with PoE power, use an 802.3at compliant source
 This is confirmed when I test the IAP-215-RW on the PD3501G with the command: show ap debug system-status:
Power Status ------------ Operational State POE-AF: USB port disabled; ----------------- -------------------------- Current HW State POE-AF: USB port disabled; LLDP Negotiated POE Power 0.0W
So, you are good to go, unless you really need the USB port for a 3G/4G uplink or so...
No risk of overheating because of the chosen power injector, because you are working within specifications.
