Campus Switching and Routing
I would like to know how to configure a switch, and I would like to know about q tagging.
Re: Configuration
Your question is fairly broad and open.  You should start with the User Guides and Reference Guides for the make and model you want to configure.
An explanation of dot1q tagging is here
ACCP, ACCX #817, ACMP, ACMX #294
