Campus Switching and Routing
Configure Interface IP on Aruba 2930F
Hi, need some help on Aruba switch as this is first time using Aruba switch.
Want to configure something like Cisco command in Aruba Switch 2030F but cant get it right...as I can only see VLAN configuration.
Cisco(config)#interface fastEthernet 0
Cisco(config-if)#ip address 10.199.111.41 255.255.255.0
Or this Aruba switch does not support Interface IP for L3 purpose?
Re: Configure Interface IP on Aruba 2930F
You can only add an IP address to a VLAN. A switchport is an L2 construct.
Tim Cappalli | Aruba Security
This is the feature in 2930F series?
How can i find the one which allows me to define L3 interface as what Cisco switch capable of?
I have some STP bpdu issue with Cisco switch, and would think a router port configuration would eliminate this problem.
They are switchports. You cannot directly assign an IP address.
Contributor I
In ArubaOS Switch you can´t put a physical interface in route mode.
#You have to create an L3 vlan interface
conf t
interface vlan XX
  ip address 10.10.10.1 255.255.255.252
  exit
#Then you have to untag that vlan on the interface connected to the other device
interface 24
  untag vlan XX
exit
If it helps please add Kudos
To clarify a bit on the syntax for ArubaOS-Switch: there is only one VLAN context (as opposed to the split 'VLAN' and 'VLAN interface' used by Cisco, Comware, etc); this context is used for both L3 configuration as well as assigning the VLAN to ports.
switch# configure
switch(config)# vlan 10
switch(vlan-10)# ip address 172.16.0.1/16
switch(vlan-10)# untag 1
switch(vlan-10)# tag 24
switch(vlan-10)# exit
switch(config)#
Matthew Fern | Technical Marketing Engineer, Campus Networking
Aruba, a Hewlett Packard Enterprise Company
