Campus Switching and Routing
Connectivity problem with 2930F switch
Hi guys,
I am very new with Aruba switches and I have a problem with switch 2930F. I want to upgrade the firmware, the switch is new with the factory configuration. I have configured an IP address as:
switch(config)#vlan 1 ip address 192.168.1.10 255.255.255.0
Then I have configured in my laptop IP 192.168.1.2 255.255.255.0 and I have connected my laptop Ethernet port to switch port 1.
In that way, I can ping from my laptop to the switch IP address, even I can telnet into it. But I can't ping from the switch to my laptop, and when I want to download the new firmware from my laptop through TFTP to do the upgrade, the switch console shows a connectivity error with 192.168.1.2.
What could be the problem? Any ideas?
On the other hand, is there any upgrade guide for this switch? I have browsed manuals HPE ArubaOS-Switch Management and Configuration Guide K/KA/KB.16.01 and HPE ArubaOS-Switch Advanced Traffic Management Guide K/KA/KB.16.01 and there's nothing about upgrade. The only thing I have found by googling is this
https://community.spiceworks.com/how_to/82205-how-to-update-hp-switch-firmware
and works well, but I would like to find any HP upgrade official guide.
Julián
Re: Connectivity problem with 2930F switch
Do you have the windows firewall on?
As far as upgrading you should be able to run this command (assuming you are running a tftp server on your laptop)
copy tftp flash 192.168.1.2 (firmware file name).swi primary
btw, this is an easy tftp server to get running https://tftpd64.codeplex.com/
Hi Robert,
Good point, yes, I have the Windows firewall enabled. Tomorrow I will disable it and let you know.
Thanks for TFTP server link, in fact it is the one I use!
Thanks for the command for upgrading as well, I have just found a guide which includes the upgrading process (HPE ArubaOS-Switch Basic Operation Guide 16.02).
Julián
Hi Robert,
I have disabled the Windows firewall and the connectivity problem has gone, thank you very much.
For the upgrading procedure I have been able to upgrade this switch (JL253A) using the procedure you explained, however, I haven't been able to upgrade my other switch (JL259A) to the same version. This is the output:
SW-ACCESS1# copy tftp flash 10.115.70.10 WC_16_03_0007.swi primary
The primary image will be deleted.
Continue (y/n)? y
020M
Validating and Writing System Software to the Filesystem ...
SW-ACCESS1# show flash
Image Size (bytes) Date Version
Primary Image : 20530856 10/26/16 WC.16.02.0014
Secondary Image : 20530856 10/26/16 WC.16.02.0014
Boot ROM Version
Primary Boot ROM Version : WC.16.01.0003
Secondary Boot ROM Version : WC.16.01.0003
Default Boot Image : Primary
Default Boot ROM : Primary
SW-ACCESS1#
I don't know but the new software is not loaded into the primary flash, but the console doesn't throw any error. I have tried with the secondary flash and with the same result.
What could be the problem? Any workaround?
Julián
Greetings!
Are there any error messages displayed in the system log ('show log -r') related to the software image copy?
Matthew Fern | Technical Marketing Engineer, Campus Networking
Aruba, a Hewlett Packard Enterprise Company
Hi Matthew,
Thanks for your interest. I will try tomorrow that command and let you know.
Julián
Hi Matthew,
There is no error messages related to the TFTP transfer. This is what I see:
I 01/01/90 04:46:28 00002 vlan: Gestion virtual LAN disabled
I 01/01/90 04:46:28 00077 ports: port 24 is now off-line
I 01/01/90 03:50:44 04244 update: User 'manager' : Secondary Image updated via
TFTP from 10.115.70.10 completed.Firmware version: Before
update: WC.16.02.0014 After update : WC.16.02.0014
I 01/01/90 03:50:41 00163 update: Firmware image contains valid signature.
I 01/01/90 03:50:40 00131 tftp: Transfer completed
I 01/01/90 03:42:30 04244 update: User 'manager' : Primary Image updated via
I 01/01/90 03:42:27 00163 update: Firmware image contains valid signature.
I 01/01/90 03:42:26 00131 tftp: Transfer completed
I 01/01/90 03:38:56 04244 update: User 'manager' : Primary Image updated via
I 01/01/90 03:38:53 00163 update: Firmware image contains valid signature.
I 01/01/90 03:38:52 00131 tftp: Transfer completed
I 01/01/90 03:38:19 00179 mgr: SME SSH from 10.115.70.10 - MANAGER Mode
Any idea?
Julián
That is quite curious.  Have you tried re-downloading the WC.16.03.0007 image from the support site?  Alternately, I would suggest trying a different version (e.g., WC.16.04.0011) and seeing if you get the same result.  If so, I would recommend opening a support case so we can investigate the issue further.
