Campus Switching and Routing
Frequent Contributor I
Contoller GUI is not Accessable
Hi Everyone,
I have a proble while accessing my controller via GUI. The controller is accessable via secureCRT and also i am able to access the controller via GUI, the controller accept the Username and Password. But once i put the Username and Password after that nothing happened. For information i attached the Sanpshot for reference. Appricate your support in advance. Thanks.
Re: Contoller GUI is not Accessable
How long has this been happening? If you just upgraded please clear your browser cache.
Thanks cjospeh, Yes i cleaned browser cache and also tried another brower but the problem was same. Can you please suggest what step next i will do.
I received this controller from my friend, now i fix it in my network. from CLI its ok.
Did you try saving the licenses and then typing "write erase all"?
yes i "Write erase all", after saving the licenses.
What version of ArubaOS is running?
Try these :
- Open Internet Explore
- (Alt + T) + "Compatibility View Settings"
- Add your CTRL IP address on box and select "ADD"
- Close, try to reconnect to your controller
Best Regards
Yopianus Linga
