Campus Switching and Routing
Copy to/from USB on 3810M
Hello all,
How on the love of god :) can we access the usb on Aruba3810M switch ?
Aruba-Stack-3810M# show flash
Image Size (bytes) Date Version
Primary Image : 23543841 01/18/16 KB.16.01.0004
Secondary Image : 23543841 01/18/16 KB.16.01.0004
Boot ROM Version
Primary Boot ROM Version : KB.16.01.0005
Secondary Boot ROM Version : KB.16.01.0005
Default Boot Image : Primary
Default Boot ROM : Primary
Aruba-Stack-3810M# dir
Error Accessing USB Device.
Aruba-Stack-3810M# show usb
USB port status: enabled
USB port power status: power on (no USB device detected in port).
The USB was FAT32...now it is FAT...nothing.......
Why !!!
Contributor II
Re: Copy to/from USB on 3810M
Faulty USB Flash memory key? did you tried other USB Flash keys just to be sure that the one you're using is somewhat unsupported/faulty? Once the USB Flash memory key is inserted on the AUX Port, is the AUX Port's Activity LED flashing slowly in colour orange or what? Is the USB Flash key an USB 3.0 (blue plastic) or an old USB 2.0 (no blue plastic)?
How (partition's size) did you partitioned that USB Flash memory key before formatting using the FAT filesystem?
