Campus Switching and Routing
Occasional Contributor I
DHCP relay difference in Provision and Comware7
I'm currently shifting from a Procurve 5412zl to a Comware 5500 as routing switch for most of my vlans.
They both use DHCP relay to the same server, but i see a difference in the DHCP response packets from client perspective.
Comware
DHCP DISCOVER
DHCP OFFER arrived:
 From remote host: 10.26.62.1:67 target: 10.26.62.67 received on en8: 10.26.62.66:68
 yiaddr: 10.26.62.67
  OptionClientID: DHCPTest
DHCP REQUEST
DHCP ACK arrived:
 yiaddr: 10.26.62.67
Provision
DHCP DISCOVER
DHCP OFFER arrived:
 From remote host: 192.168.30.13:67 target: 10.28.3.72 received on en8: 10.28.3.71:68
 yiaddr: 10.28.3.72
DHCP REQUEST
DHCP ACK arrived:
 yiaddr: 10.28.3.72
As you can see, Comware hides the DHCP server address, where as Provision shows the actual ip address.
This means that, when using DHCP spoofing on all my connected Provision 5400, i need to add the gateway address for each subnet as trusted DHCP server.
Is there a way to configure Comware7 to NOT hide the DHCP server ip address?
Boot image: flash:/5510hi-cmw710-boot-r1122p02.bin
Boot image version: 7.1.045, Release 1122P02
Compiled Jul 03 2017 16:00:00
System image: flash:/5510hi-cmw710-system-r1122p02.bin
System image version: 7.1.045, Release 1122P02
Br,
Thomas
