Campus Switching and Routing
Direct attack cable (DAC) from Aruba 2930F to HP 5510 HI series switch.
Good day,
I was wondering if it was possible to connnect Aruba 2930F to HP 5510 HI series switch via a DAC cable. Has anyone ran into similar issues conserning this?
HPE X242 10G SFP+ to SFP+ 3m Direct Attach Copper Cable (J9283B) is the one I would be using.
Re: Direct attack cable (DAC) from Aruba 2930F to HP 5510 HI series switch.
I'm sorry but I can't test this for you but it will probably work. Only on the 5500-HI CMW based switch you will get a message in syslog that you're using unsupported tranceiver.
