Campus Switching and Routing
Do the S3500 switches support Cross-Stack EtherChannels?
I know that this is supported with Cisco but is it also possible w/ Aruba?  The examples I see only only show a module/port choice as in FE 0/1, but no examples showing that you can select different switches.
For example I would like to make an etherchannel out of GE 0/1/1, GE 0/1/2, and GE 1/1/1.  Is this possible?
Thanks in advance!
Re: Do the S3500 switches support Cross-Stack EtherChannels?
Yes
Tim
Tim Cappalli | Aruba Security
