Campus Switching and Routing
Dynamic voice VLAN assignment
Dear All,
Is it possible to enable dynamic voice vlan assignment on switch Aruba 3810M (ROM Ver: KB.16.01.0008)? Scenario: Users are authenticated via 802.1x and ipphones are authenticated via MAB thru radius server. I have ipphones form 2 different vendors and i would like them to use differen VLANs - let's say after connecting to switch Cisco ippohne will be assigned to vlan 90 and after connecting Alcatel ipphone to same port will be assigned to vlan 100.
Is it possible?
Thanks for any help!
Re: Dynamic voice VLAN assignment
Greetings!
Can you please share your config?  I'll replicate the issue in my lab and confirm the findings.
Thank You,
Pri
Priyank Patel
Frequent Contributor I
If you are using ClearPass, you can create a policy like:
Authorization:Endpoint Repository equals VoIP Phone AND
Connection:Client-Mac-Vendor equals Cisco
Then assign Enforcement profile for VLAN 90
Connection:Client-Mac-Vendor equals Alcatel
Then assign Enforcement profile for VLAN 100
For this policy to work, make sure DHCP profiling is working with ClearPass.
JayBee
ACDX | ACCX| CCIE (RnS/SP,DC) | ACCP | ACMP | ACSA | ACMA | JNCIS | JNCIA
If the provided solution resolves your issue, please mark it as accepted solution to help others.
