Campus Switching and Routing
Enhanced support for Aruba AP on ArubaOS switches with release 16.01
With the latest code for Aruba OS switches we are introducing 3 new automatic features to support easier deployment of ARUBA Aps.
  1. Set POE Priority- when an ARUBA AP is connected to the switch port, the switch automatically detect that it is an ARUBA AP and will assign the highest PoE priority to that port.
  2. Rogue AP Containment- when a rogue AP is detected the switch will shut down the port, and block all traffic to it.
  3. Auto VLAN configuration- when an authorized ARUBA AP is connected and configured with multiple SSIDs and VLANS the switch will automatically add those VLAN to the configuration.
