Campus Switching and Routing
Example Document for Radius and Port base access (802.1X)configuration in Aruba 5400R
Anyone please share me the Radius and Port base access (802.1X) configuration example document for Aruba 5400R swicth.
Thanks Regards
Rahbar
Occasional Contributor I
Re: Example Document for Radius and Port base access (802.1X)configuration in Aruba 5400R
You can refer to the 5400R Access security Guide for Configuration Assistance.
