Campus Switching and Routing
GRE tunnel wizard showing ip address not configured what may be the reason and why
GRE tunnel wizard showing ip address not configured what may be the reason and why?
Mallikarjun
Re: GRE tunnel wizard showing ip address not configured what may be the reason and why
That is because only a layer 3 GRE tunnel requires an ip address.  A layer 2 tunnel does not.
Then what is that ip address assigned to ,already  we are entered source and destination ip address right? Will you please explain it .
Mallikarjun
If it is a layer 2 tunnel, there is no ip address; it is just basically bridging traffic.  If there is a layer 3 tunnel, typically there is an ip address because there is a route added to point to the subnet represented by the tunnel.
