Campus Switching and Routing
Occasional Contributor I
GVRP Configuration issue on Aruba S2500-24P switch
We are working on Aruba switch and wants to Maintain VLAN Consistency across the networked environment, as per my understanding VTP is a cisco proprietary protocol and hence does not supported by Aruba.
Instead of VTP Aruba is using GVRP. I am unable to find GVRP command in my switch. I would really appreciate if you can help me to configure it. Thanks
Below are the switch information you might request
Model:                 ArubaS2500-24P
Serial No:            BY0001123
Re: GVRP Configuration issue on Aruba S2500-24P switch
The MAS product line does indeed support GVRP.
Enable GVRP Globally
(S2500)(config)# gvrp
(S2500)(Global GVRP configuration)# enable
(S2500)(Global GVRP configuration)# join-time <milliseconds>
Create an interface GVRP profile
(S2500)(config)# interface-profile gvrp-profile Enable-GVRP
(S2500)(Interface GVRP profile “Enable-GVRP”)# enable
(S2500)(Interface GVRP profile “Enable-GVRP”)# registrar-mode normal
Attach the profile to an interface or interface-group
(S2500) (config) # interface gigiabitethernet 0/0/10
(S2500) (gigabitethernet "0/0/10") # gvrp-profile gvrp
Some verification commands
show gvrp-global-profile
 show gvrp interfaces
Tim Cappalli | Aruba Security
Thanks but the problem is that I am unable  to see GVRP Command
I am using SSH connection and its giving me the following error after i enter into configurator terminal
"Invalid input detected at '^' marker."
I am using ArubaOS 7.1.3.2
Please suggest
I believe GVRP support was added in 7.2.x to complement the Instant AP integration.
How can I update the firmware?
Download the image from support.arubanetworks.com
Then you have two options:
1) Upload through the web GUI
Go to Maintenance > Image Management and look to see which parition is "default boot".
Then upload the new image to the other partition using the "local file" option.
2) Via SCP or TFTP server
- Copy the image to the server
- From the CLI issue, show image version. This will tell you which image is active (default boot).
   - For SCP: copy scp: <server ip> <username> <filename> system: partition <opposite partition number>
   - For TFTP: copy tftp: <server ip> <filename> system: partition <opposite partition number>
- write mem
- reload
Dear Cappalli,
Thanks its working fine now.
Dear Cappalli,
Like in VTP we can have Client , Server & Transparent mode. How can we make one client one server and one switch in transparent mode. Any suggestions.
I don't think there is an equivalent with GVRP. The switches negotiate the VLAN trunks with their neighbors.
Thank you for your support, I have upgraded the firmware and now I am able to see GVRP command. Can you please clarify like in VTP we create client, server and transparent. I am using 3 switches One I want to create a server and other two client and transparent. How can I do that? A basic sample I’ve seen in User manual can you send me the list of commands I have to apply on each .
In addition to above.Can you please also clarify
Q:1:: 1Cisco switch and 3 Aruba switch and we need to maintain VLAN consistency across the network How we will do it, e.g If cisco is acting as a VTP Server mode.
Q:2: : How we have to configure Aruba switch if we want to make cisco switches client and other aruba switch also a client.
