Campus Switching and Routing
Trusted Contributor I
Get S3500 Uplink Module Serial Number
Is there any way to remotely obtain the uplink module's serial number?  It doesn't report in "show version" or "show inventory".  Need it for inventory purposes.
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
Re: Get S3500 Uplink Module Serial Number
Try this:  http://community.arubanetworks.com/t5/Wired-Networks/How-to-display-detailed-interface-transceiver-information-on/ta-p/180614
I am quite sure the serial number for the expansion module is on the "show inventory" under the heading "Module 1 Serial #"
