Campus Switching and Routing
HA active active help!!
I recently migrated from VRRP to HA fast failover active active. I created 2 profiles, 1 for set A APs and 1 for set B aps to load balance. After I configured the LMS ip all clients are still going to 1 controller. what should be done? Its not using the other controller.
Re: HA active active help!!
Are both controllers set to 'dual' mode with respect to HA?
ACCP, ACCX #817, ACMP, ACMX #294
Yes sir both controllers are in dual mode and both are masters. Another question, Do I need to change the master master to master local for easier management
