Campus Switching and Routing
Contributor I
HA active active inquiry
Hi we have 2 controllers and I migrated from VRRP to HA both set as dual role for active active deployment. What is the best settings of my controllers? is it master-master or master-local?
Re: HA active active inquiry
If you want APs terminating on both controllers, which I assume you do as you have them in dual mode, you will want to utilise the master - local architecture.
Cheers
James
Cheers
James
-------------------@whereisjrw-------------------
------------------------blog-------------------------
