Campus Switching and Routing
HELP!!! How to migrate from VRRp to HA Active active with minimal downtime
How can I migrate from vrrp to HA active active controller? Do I need to reconfigure all APs? Thanks.
Re: HELP!!! How to migrate from VRRp to HA Active active with minimal downtime
 Below thread should answer your question
http://community.arubanetworks.com/t5/Wireless-Access/Migrating-from-VRRP-failover-to-HA-fast-failover/td-p/151550
Rajaguru Vincent
CWNA | CWSP | CWAP | CWDP | ACMP
Do I need to reconfigure AP's master?
No, Master-IP can remain the same.
Rajaguru Vincent
