Campus Switching and Routing
HOW to isolete ports on comware7
Hello Community!!
I need isolete traffic of diferents ports, for example I have vlan 30 with a lot of servers (physical servers and virtual servers) and they must not communicate between them.
I tryed with port isoleted but it doesnt work:
sys
port-isolate group 1
interface range gig1/0/2 to gig 1/0/24
 port-isolate enable group 1
I tryed with private vlan, but its a really long configuration!!
do you have any idea to share:)
best regard...
Regular Contributor I
Re: HOW to isolete ports on comware7
Are all of the servers on the same switch?
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
If you like my posts, kudo's are welcome. If it solves your problem, please click 'Accept as Solution'
Then port isolate should work
Cheers, Frank
Hello mrzero,
Is a mix, some servers are in the same IRF stack and others in second IRF stack.
The fact is that isoleted-port doesnt work!! the servers can ping between them :(
port isolation only works on the same switch, if you need this across multiple switches then isolated private-vlans is the answer to your request.
