Campus Switching and Routing
HP ARUBA 2930F SWITCH
I am new to this community and wanted to learn more about hp switches
Currently we have hp 2930 as stacks using chain topolgy.
We have several vlan setups.
I am struggling to configure member 2 in the stack through the commander.
For example if I want to configure a port which is located on switch member 2 port 2/34 onto (vlan office) from (Vlan Reception) what are the commands.
If someone can tell me step by step commands please much appreciated.
Regards
Re: HP ARUBA 2930F SWITCH
Are these all part of the same VSF?
ACMA, ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
On ArubaOS switches, you configure the VLAN and then attach ports to it either untagged or tagged.
For example if your Office VLAN is VLAN2, and port 1/8, 2/2 through 2/5 must be access ports in that VLAN, and port 1/5 is the (tagged) uplink, the config could be like this:
vlan 2
   name "Office"
   untagged 1/8,2/2-2/5
   tagged 1/5
   ip address 10.254.1.1 255.255.255.0
   exit
Is that what you are looking for?
