Campus Switching and Routing
Occasional Contributor I
HP/Aruba 2930F 48G PoE+ 4SFP JL262A VSF
Is it possible to configure VSF with the HP/Aruba 2930F 48G PoE+ SFP (JL262A) switches? Doesn't the VSF setup require at least one 10G fiber, 10G DAC, 10G copper (SR), or 40G DAC connection?
dvi
Re: HP/Aruba 2930F 48G PoE+ 4SFP JL262A VSF
You can also configure VSF with 1G links. You only need to make sure that all port speeds across the VSF stack are the same.
Regards, Dobias
