Campus Switching and Routing
Occasional Contributor I
HP2920 Tagged / UnTagged Ports
I am a little confused by tagged/untagged.   I have a HP 2920 that will be part of a stack (total 4 2920 switches)  I have stack enabled and also routing is enabled.  I have this switch connected  (uplink) on Port 1/2 for now while I test.  I tried to tag this port for VLAN 6 and the switch freezes and I have to console into it so I can untag the port.  Doesn't the uplink need to be tagged in the VLAN's I want it to carry?  I also tried to assign a IP to VLAN 7 but i cant ping it.  The IP is on 10.0.7.0/24 network.  From this switch I can ping another IP on the 10.0.7.0/24 network.
stacking
   member 1 type "J9729A" mac-address d06726-798700
   member 1 priority 255
   exit
hostname "3850Stack"
aruba-central disable
no rest-interface
time daylight-time-rule continental-us-and-canada
ip route 0.0.0.0 0.0.0.0 10.0.2.XXX
ip routing
snmp-server community "public" unrestricted
oobm
   ip address dhcp-bootp
   member 1
      exit
   exit
vlan 1
   name "DEFAULT_VLAN"
   no untagged 1/1-1/48
   no ip address
   exit
vlan 3
   name "DATA_VLAN"
   untagged 1/1-1/48
   ip address 10.0.2.XXX 255.255.255.0
   exit
vlan 6
   name "VOICE_VLAN"
   no ip address
   exit
vlan 7
   name "WIFI_VLAN"
   no ip address
   exit
vlan 9
   name "MGMT_VLAN"
   no ip address
   exit
vlan 10
   name "CAM_VLAN"
   no ip address
   exit
no tftp server
no autorun
no dhcp config-file-update
no dhcp image-file-update
no dhcp tr69-acs-url
password manager
mkk
Contributor II
Re: HP2920 Tagged / UnTagged Ports
Vlan6
Tagged 1/2
Also use voice vlan for vlan6 to have lldp-med working for your phones.
Why routing enabled, you have just one ip interface on the data vlan.
Where do you do switch management, on the data vlan ip interface? Make one for de management vlan.
Is spanning-tree enabled, maybe you make a loop somewhere.
Routing is enabled because this stack will be replacing my HP Procurve which is EOL.  I set IP for the WIFI VLAN    I added voice to the Voice VLAN.  I can ping the IP address and can ping things on the WIFI network but when I try to do a VNC to something on the 10.0.7.0/24 network I cant connect.
I set IP's on my CAM_VLAN and MGMT_VLAN but can ping them even within the switch.
; hpStack_WB Configuration Editor; Created on release #WB.16.02.0012
; Ver #0e:01.b0.ee.34.5f.3c.29.eb.9f.fc.f3.ff.37.ef:73
stacking
exit
no rest-interface
ip routing
oobm
member 1
exit
exit
vlan 1
name "DEFAULT_VLAN"
no ip address
exit
vlan 3
name "DATA_VLAN"
untagged 1/1-1/48
exit
vlan 6
name "VOICE_VLAN"
no ip address
voice
exit
vlan 7
name "WIFI_VLAN"
ip address 10.0.7.XXX 255.255.255.0
exit
vlan 9
name "MGMT_VLAN"
ip address 10.0.15.XXX 255.255.255.0
exit
vlan 10
name "CAM_VLAN"
ip address 10.0.14.XXX 255.255.255.0
exit
no tftp server
no autorun
password manager
Frequent Contributor I
Can you provide us the VLANs status by showing us the outputs of show vlans and show vlans custom state:5 CLI commands?
I suspect some of your VLANs are not in Up state (no ports was ever connected in state Up as member of those VLANs).
mkk
Contributor II
Can you provide a “show logging -r”.
mkk
Contributor II
FYI The stack is setup so I have 4 2920's.
So if I wanted 4/1-4/20 to be on my Cam_VLAN in VLAN 10 I would untag 4/1-4/20 ?
Here is the result of sh vlans
Status and Counters - VLAN Information
  Maximum VLANs to support : 256
  Primary VLAN : DEFAULT_VLAN
  Management VLAN :
  VLAN ID Name                             | Status     Voice Jumbo
  1       DEFAULT_VLAN                     | Port-based No    No
  3       DATA_VLAN                        | Port-based No    No
  6       VOICE_VLAN                       | Port-based Yes   No
  7       WIFI_VLAN                        | Port-based No    No
  9       MGMT_VLAN                        | Port-based No    No
  10      CAM_VLAN                         | Port-based No    No
3850Stack# sh vlans custom state:5
Status and Counters - VLAN Information - Custom view
 State
 Down
 Up
 Down
 Down
 Down
 Down
Config now:
stacking
   member 2 type "J9729A" mac-address d06726-799280
   member 3 type "J9729A" mac-address d06726-7dd000
   member 4 type "J9729A" mac-address d06726-801cc0
   exit
no rest-interface
ip routing
oobm
   member 1
      exit
   member 2
      exit
   member 3
      exit
   member 4
      exit
   exit
vlan 1
   name "DEFAULT_VLAN"
   untagged 2/1-2/48,3/1-3/48,4/1-4/48
   no ip address
   exit
vlan 3
   name "DATA_VLAN"
   untagged 1/1-1/48
   ip address 10.0.2.22 255.255.255.0
   exit
vlan 6
   name "VOICE_VLAN"
   no ip address
   voice
   exit
vlan 7
   name "WIFI_VLAN"
   ip address 10.0.7.17 255.255.255.0
   exit
vlan 9
   name "MGMT_VLAN"
   ip address 10.0.15.254 255.255.255.0
   exit
vlan 10
   name "CAM_VLAN"
   ip address 10.0.14.2 255.255.255.0
   exit
no tftp server
no autorun
password manager
Thanks for the quick response.  I appreciate it.
Press any key to continue[?25h[?6l[?7lYour previous successful login (as manager) was on 1990
-01-01 00:37:36
 from 10.0.2.134
[?25h3850Stack# [?25hs[?25hh[?25h
[24;14H[?25hl[?25ho[?25hg[?25hg[?25h[?25h
[1;24r[?25h3850Stack# sh logging [?25h-[?25hr[?25h
[24;0HE[?25h Keys:   W=Warning   I=Information
         M=Major     D=Debug E=Error
----  Reverse event Log listing: Events Since Boot  ----
I 01/01/90 00:38:58 00179 mgr: ST1-CMDR: SME SSH from 10.0.2.134 - MANAGER Mode
I 01/01/90 00:38:56 03362 auth: ST1-CMDR: User 'manager' logged in from
            10.0.2.134 to SSH  session
I 01/01/90 00:38:27 03363 auth: ST1-CMDR: User 'manager' logged out of SSH
            session from  10.0.2.134
I 01/01/90 00:37:38 00179 mgr: ST1-CMDR: SME SSH from 10.0.2.134 - MANAGER Mode
I 01/01/90 00:37:36 03362 auth: ST1-CMDR: User 'manager' logged in from
I 01/01/90 00:37:15 03363 auth: ST1-CMDR: User 'manager' logged out of SSH
I 01/01/90 00:35:09 00179 mgr: ST1-CMDR: SME SSH from 10.0.2.134 - MANAGER Mode
I 01/01/90 00:35:07 03362 auth: ST1-CMDR: User 'manager' logged in from
I 01/01/90 00:33:48 03363 auth: ST1-CMDR: User 'manager' logged out of SSH
I 01/01/90 00:30:02 00131 tftp: ST1-CMDR: Transfer completed
I 01/01/90 00:26:35 00179 mgr: ST1-CMDR: SME SSH from 10.0.2.134 - MANAGER Mode
I 01/01/90 00:26:34 03362 auth: ST1-CMDR: User 'manager' logged in from
I 01/01/90 00:06:10 05083 chassis: ST1-CMDR: Ports 3/37-48: PoE Software updated
-- MORE --, next page: Space, next line: Enter, quit: Control-C            from version 04 to 38.
I 01/01/90 00:06:10 05083 chassis: ST1-CMDR: Ports 4/37-48: PoE Software updated
I 01/01/90 00:06:10 05083 chassis: ST1-CMDR: Ports 2/37-48: PoE Software updated
I 01/01/90 00:06:03 05083 chassis: ST1-CMDR: Ports 4/25-36: PoE Software updated
I 01/01/90 00:06:03 05083 chassis: ST1-CMDR: Ports 3/25-36: PoE Software updated
I 01/01/90 00:06:03 05083 chassis: ST1-CMDR: Ports 2/25-36: PoE Software updated
I 01/01/90 00:05:55 05083 chassis: ST1-CMDR: Ports 4/13-24: PoE Software updated
I 01/01/90 00:05:55 05083 chassis: ST1-CMDR: Ports 3/13-24: PoE Software updated
I 01/01/90 00:05:55 05083 chassis: ST1-CMDR: Ports 2/13-24: PoE Software updated
I 01/01/90 00:05:48 05083 chassis: ST1-CMDR: Ports 4/1-12: PoE Software updated
I 01/01/90 00:05:48 05083 chassis: ST1-CMDR: Ports 3/1-12: PoE Software updated
I 01/01/90 00:05:48 05083 chassis: ST1-CMDR: Ports 2/1-12: PoE Software updated
-- MORE --, next page: Space, next line: Enter, quit: Control-CI 01/01/90 00:05:45 02555 chassis: ST1-CMDR: Co-
processor Ready
I 01/01/90 00:05:45 02555 chassis: ST1-CMDR: Co-processor Ready
I 01/01/90 00:05:43 03803 chassis: ST1-CMDR: System Self test completed on
            4/1-48
            3/1-48
            2/1-48
I 01/01/90 00:05:43 00540 stacking: ST1-CMDR: Redundant Standby Management
            Module syncing is complete. Configuration changes are allowed
I 01/01/90 00:05:43 03260 stacking: ST3-STBY: Member booted
I 01/01/90 00:04:50 00540 stacking: ST1-CMDR: Redundant Standby Management
            Module syncing is in progress. Configuration changes are temporarily
            blocked
I 01/01/90 00:04:50 02682 OOBM: ST2-MMBR: OOBM - Enabled globally.
I 01/01/90 00:03:16 02553 chassis: ST2-UKWN: Loading of Co-processor OS image
            complete.
I 01/01/90 00:03:15 02552 chassis: ST2-UKWN: Loading of Co-processor OS image in
            progress.
I 01/01/90 00:03:15 02550 chassis: ST2-UKWN: Requesting Co-processor OS image
            location in flash.
I 01/01/90 00:00:52 02558 chassis: ST2-UKWN: Stack port 1 is now on-line.
-- MORE --, next page: Space, next line: Enter, quit: Control-CI 01/01/90 00:00:48 02558 chassis: ST2-UKWN: Stack port
2 is now on-line.
I 01/01/90 00:00:46 02556 chassis: ST2-UKWN: Stack port 1 cable inserted.
I 01/01/90 00:00:44 02557 chassis: ST2-UKWN: Stack port 1 cable removed.
I 01/01/90 00:00:41 02556 chassis: ST2-UKWN: Stack port 2 cable inserted.
I 01/01/90 00:00:41 02556 chassis: ST2-UKWN: Stack port 1 cable inserted.
I 01/01/90 00:00:31 00550 chassis: ST2-UKWN: Stacking Module inserted
I 01/01/90 00:00:31 03803 chassis: ST2-UKWN: System Self test completed on
            Master
I 01/01/90 00:00:31 03802 chassis: ST2-UKWN: System Self test started on  Master
            Master
I 01/01/90 00:00:30 03802 chassis: ST2-UKWN: System Self test started on  Master
I 01/01/90 00:04:49 02682 OOBM: ST4-MMBR: OOBM - Enabled globally.
I 01/01/90 00:02:54 02553 chassis: ST4-UKWN: Loading of Co-processor OS image
            complete.
I 01/01/90 00:02:54 02552 chassis: ST4-UKWN: Loading of Co-processor OS image in
            progress.
I 01/01/90 00:02:54 02550 chassis: ST4-UKWN: Requesting Co-processor OS image
            location in flash.
I 01/01/90 00:00:58 02558 chassis: ST4-UKWN: Stack port 1 is now on-line.
I 01/01/90 00:00:52 02556 chassis: ST4-UKWN: Stack port 1 cable inserted.
-- MORE --, next page: Space, next line: Enter, quit: Control-CI 01/01/90 00:00:50 02557 chassis: ST4-UKWN: Stack port
1 cable removed.
I 01/01/90 00:00:47 02559 chassis: ST4-UKWN: Stack port 1 is now off-line.
I 01/01/90 00:00:47 02558 chassis: ST4-UKWN: Stack port 2 is now on-line.
I 01/01/90 00:00:38 02556 chassis: ST4-UKWN: Stack port 2 cable inserted.
I 01/01/90 00:00:38 02556 chassis: ST4-UKWN: Stack port 1 cable inserted.
I 01/01/90 00:00:36 02557 chassis: ST4-UKWN: Stack port 2 cable removed.
I 01/01/90 00:00:36 02557 chassis: ST4-UKWN: Stack port 1 cable removed.
I 01/01/90 00:00:32 02556 chassis: ST4-UKWN: Stack port 2 cable inserted.
I 01/01/90 00:00:32 02556 chassis: ST4-UKWN: Stack port 1 cable inserted.
I 01/01/90 00:00:23 00550 chassis: ST4-UKWN: Stacking Module inserted
I 01/01/90 00:00:22 03803 chassis: ST4-UKWN: System Self test completed on
            Master
I 01/01/90 00:00:22 03802 chassis: ST4-UKWN: System Self test started on  Master
            Master
I 01/01/90 00:00:21 03802 chassis: ST4-UKWN: System Self test started on  Master
I 01/01/90 00:04:49 03260 stacking: ST2-MMBR: Member booted
I 01/01/90 00:04:49 03260 stacking: ST4-MMBR: Member booted
I 01/01/90 00:04:49 03802 chassis: ST1-CMDR: System Self test started on 2/1-48
I 01/01/90 00:04:49 03802 chassis: ST1-CMDR: System Self test started on 4/1-48
I 01/01/90 00:04:49 00539 stacking: ST1-CMDR: Initial sync to member 4 complete
-- MORE --, next page: Space, next line: Enter, quit: Control-CI 01/01/90 00:04:49 00539 stacking: ST1-CMDR: Initial
sync to member 2 complete
I 01/01/90 00:04:48 03802 chassis: ST1-CMDR: System Self test started on 3/1-48
I 01/01/90 00:04:22 00179 mgr: ST1-CMDR: SME CONSOLE Session - MANAGER Mode
I 01/01/90 00:04:22 03362 auth: ST1-CMDR: User 'manager' logged in from 0.0.0.0
            to CONSOLE  session
I 01/01/90 00:03:55 05083 chassis: ST1-CMDR: Ports 1/37-48: PoE Software updated
I 01/01/90 00:03:48 05083 chassis: ST1-CMDR: Ports 1/25-36: PoE Software updated
I 01/01/90 00:03:40 05083 chassis: ST1-CMDR: Ports 1/13-24: PoE Software updated
I 01/01/90 00:03:32 00001 vlan: ST1-CMDR: DATA_VLAN virtual LAN enabled
I 01/01/90 00:03:32 00076 ports: ST1-CMDR: port 1/48 is now on-line
I 01/01/90 00:03:32 05083 chassis: ST1-CMDR: Ports 1/1-12: PoE Software updated
I 01/01/90 00:03:29 02555 chassis: ST1-CMDR: Co-processor Ready
I 01/01/90 00:03:29 00539 stacking: ST1-CMDR: Initial sync to member 4 starting
I 01/01/90 00:03:29 00539 stacking: ST1-CMDR: Initial sync to member 2 starting
I 01/01/90 00:03:29 00539 stacking: ST1-CMDR: Initial sync to standby starting
I 01/01/90 00:03:28 03271 stacking: ST1-CMDR: Topology is a Ring
I 01/01/90 00:03:27 03803 chassis: ST1-CMDR: System Self test completed on
            1/1-48
I 01/01/90 00:03:23 03401 crypto: ST1-CMDR: Function POWER UP passed selftest.
-- MORE --, next page: Space, next line: Enter, quit: Control-CI 01/01/90 00:03:22 03802 chassis: ST1-CMDR: System Self
test started on 1/1-48
I 01/01/90 00:03:21 02553 chassis: ST1-CMDR: Loading of Co-processor OS image
            complete.
I 01/01/90 00:03:20 02552 chassis: ST1-CMDR: Loading of Co-processor OS image in
            progress.
I 01/01/90 00:03:20 02550 chassis: ST1-CMDR: Requesting Co-processor OS image
            location in flash.
I 01/01/90 00:03:19 03260 stacking: ST1-CMDR: Member booted
I 01/01/90 00:03:19 03261 stacking: ST1-CMDR: Member active
I 01/01/90 00:03:19 00066 system: ST1-CMDR: System Booted
I 01/01/90 00:03:19 05256 central: ST1-CMDR: Connection to Aruba Central server
            has been disabled.
I 01/01/90 00:03:19 05258 central: ST1-CMDR: Aruba Central support mode is
            disabled.
I 01/01/90 00:03:19 04260 dhcp-server: ST1-CMDR: Conflict-logging is disabled
I 01/01/90 00:03:19 04257 dhcp-server: ST1-CMDR: Ping-check configured with
            retry count = 2, timeout = 1
I 01/01/90 00:03:19 02012 mtm: ST1-CMDR: A non-multicast client: Non-Mcast
            client Op, is registered with client ID:  1
I 01/01/90 00:03:19 00410 SNTP: ST1-CMDR: Client is enabled.
I 01/01/90 00:03:19 02633 SNTP: ST1-CMDR: Client authentication is disabled.
I 01/01/90 00:03:19 00688 lldp: ST1-CMDR: LLDP - enabled
I 01/01/90 00:03:18 00417 cdp: ST1-CMDR: CDP enabled
-- MORE --, next page: Space, next line: Enter, quit: Control-CI 01/01/90 00:03:18 04695 auth: ST1-CMDR: Command
authorization method set to
            none.
I 01/01/90 00:03:18 00433 ssh: ST1-CMDR: Ssh server enabled
I 01/01/90 00:03:18 00110 telnet: ST1-CMDR: telnetd service enabled
I 01/01/90 00:03:17 02638 srcip: ST1-CMDR: RADIUS oper policy for IPv6 is
            'outgoing interface'
I 01/01/90 00:03:17 02637 srcip: ST1-CMDR: RADIUS admin policy for IPv6 is
I 01/01/90 00:03:17 02638 srcip: ST1-CMDR: SFLOW oper policy is 'outgoing
            interface'
I 01/01/90 00:03:17 02637 srcip: ST1-CMDR: SFLOW admin policy is 'outgoing
            interface'
I 01/01/90 00:03:17 02638 srcip: ST1-CMDR: SNTP oper policy is 'outgoing
            interface'
I 01/01/90 00:03:17 02637 srcip: ST1-CMDR: SNTP admin policy is 'outgoing
            interface'
I 01/01/90 00:03:17 02638 srcip: ST1-CMDR: TFTP oper policy is 'outgoing
            interface'
I 01/01/90 00:03:17 02637 srcip: ST1-CMDR: TFTP admin policy is 'outgoing
            interface'
I 01/01/90 00:03:17 02638 srcip: ST1-CMDR: TELNET oper policy is 'outgoing
            interface'
-- MORE --, next page: Space, next line: Enter, quit: Control-CI 01/01/90 00:03:17 02637 srcip: ST1-CMDR: TELNET admin
policy is 'outgoing
            interface'
I 01/01/90 00:03:17 02638 srcip: ST1-CMDR: SYSLOG oper policy is 'outgoing
            interface'
I 01/01/90 00:03:17 02637 srcip: ST1-CMDR: SYSLOG admin policy is 'outgoing
            interface'
I 01/01/90 00:03:17 02638 srcip: ST1-CMDR: RADIUS oper policy is 'outgoing
            interface'
I 01/01/90 00:03:17 02637 srcip: ST1-CMDR: RADIUS admin policy is 'outgoing
            interface'
I 01/01/90 00:03:17 02638 srcip: ST1-CMDR: TACACS oper policy is 'outgoing
            interface'
I 01/01/90 00:03:17 02637 srcip: ST1-CMDR: TACACS admin policy is 'outgoing
            interface'
I 01/01/90 00:03:17 00690 udpf: ST1-CMDR: DHCP relay agent feature enabled
I 01/01/90 00:03:17 02604 dhcpv6r: ST1-CMDR: Inclusion of client link-layer
            address in DHCPv6 relay message is disabled.
I 01/01/90 00:03:16 02682 OOBM: ST1-CMDR: OOBM - Enabled globally.
I 01/01/90 00:03:16 02759 chassis: ST1-CMDR: Savepower LED timer is OFF.
I 01/01/90 00:03:16 02712 console: ST1-CMDR: USB console cable disconnected
M 01/01/90 00:03:16 03001 system: ST1-CMDR: System reboot due to Power Failure
I 01/01/90 00:03:16 00062 system: ST1-CMDR: Member 1 went down without saving
-- MORE --, next page: Space, next line: Enter, quit: Control-C            crash information
I 01/01/90 00:03:16 00061 system: ST1-CMDR: ------------------------------------
I 01/01/90 00:02:40 00061 system: ST1-CMDR: ------------------------------------
I 01/01/90 00:02:40 03267 stacking: ST1-CMDR: Failover occurred
I 01/01/90 00:02:39 03279 stacking: ST1-UKWN: Member 3 (d06726-7dd000) chosen as
            standby. Reason: Standby distance from commander
I 01/01/90 00:02:29 03278 stacking: Member 1 (d06726-798700) elected as
            commander. Reason: Highest switch priority
I 01/01/90 00:01:18 02558 chassis: Stack port 2 is now on-line.
I 01/01/90 00:01:16 02559 chassis: Stack port 2 is now off-line.
I 01/01/90 00:01:02 02558 chassis: Stack port 1 is now on-line.
I 01/01/90 00:00:41 02556 chassis: Stack port 2 cable inserted.
I 01/01/90 00:00:41 02556 chassis: Stack port 1 cable inserted.
I 01/01/90 00:00:31 00550 chassis: Stacking Module inserted
I 01/01/90 00:00:31 03803 chassis: System Self test completed on  Master
I 01/01/90 00:00:31 03802 chassis: System Self test started on  Master
I 01/01/90 00:00:30 03802 chassis: System Self test started on  Master
----  Top of Log : Events Listed = 149  ----
[?25h3850Stack# [?25h [?25h [?25he
[24;14H[?25hx[?25hi[?25ht[?25hE[?25h
[1;24r[?25h3850Stack> [?25he[?25hx[?25h
[24;14Hi[?25ht[?25hE[?25h[?
25hDo you want to log out (y/n)? [?25hy[?25hE[?25h
[1;24r[?7l[?6l[?25h[?6l[?7l
mkk
Contributor II
"So if I wanted 4/1-4/20 to be on my Cam_VLAN in VLAN 10 I would untag 4/1-4/20 ?"
Yes
# configure terminal
# vlan 10
# untagged 4/1-4/20
# write memory
Better spread them around all four switches ;)
Good I got that. I want to but my boss wants them together
Sent from my iPhone
