Campus Switching and Routing
HPE OfficeConnect 1920S
Hi, i don't know if this is the correct place to ask this question...
i have a problem with a switch HPE 1920S.
When i want to make a backup of configuration appears an error:
Error: File Write Failed.
It is in the last firmware, with previous firmware happens the same.Error Backup.jpgOnly happens with Backup Configuration, other options i can do the backup.backup options.jpg
Anyone know what might be happening?
Thanks for all.
Re: HPE OfficeConnect 1920S
Feel free to reach out the support team, they'll help you out.
http://h17007.www1.hpe.com/OfficeConnect/
This is not exactly an issue with the switch or its code. You probably don't have a backup config created yet. Change the drop down menu option to startup configuration and then try the transfer again. It should work. I lost a couple of hours on this.
