Campus Switching and Routing
Hands on lab with HPE VSR router
Learn how to configure the MSR (physical routers) with the VSR (Virtual Services Router).  Download a free trial of the VSR from Download the VSR here. The VSR router can run on KVM, ESXi, VM Workstation or even Oracle VirtualBox.
Next, download the VSR Hands on Lab Configuration Guide.  Following the guide will help you understand the command line of Comware v7, from setting up basic system information to creating branch WAN connections over OSPF or BGP, IPsec tunneling and much more.
See how easy it is to create your own network environment with the VSR.  If you need 90 license keys, go to My Networking Portal, create an account, if you don't already have one, and under licenses you can pick the VSR eval license option.
Post here if you have issues.
