Campus Switching and Routing
Contributor II
Hardware software compatibility
I'm quite new with Aruba.
I'm leafing through Aruba documentation and I'm not able to find a document that list the compatibility of the Aruba Hardware and software.
Could somebody suggest me where to find it?
Thanks!
Best regards.
Michele
Re: Hardware software compatibility
Each new version's release notes has a section about hardware compatibility. You can also look here to find end of life information including final supported release: http://www.arubanetworks.com/support-services/end-of-life/#AccessPoints
Tim Cappalli | Aruba Security TME
Contributor II
Thank you for your answer!
