Campus Switching and Routing
High CPU Usage on J9727A 2920-24G-PoE+ Switch
I have  a stack of  4 -2920 switches ring topology and the CPU constantly runs above 70%.
Task usage for last 9 seconds
% CPU | Description
25.7 | Idle
4.4 | Sessions & I/O
0.8 | Hardware Mgmt
68.1 | System Services
0.3 | HTTP
0.8 | TFTP
I was looking to find out what funtion is the  System Services process and is this normal behavior. My other stack of 4 2920 same setup up are not experiancing this behavior. The software version is WB16.04.008 also viewing the process tracker System Services-36 is consuming 66 %
Any feedback would be helpful.
Thanks!
Tameka H
Process tracker state: ACTIVE
Process tracking time: 30 seconds
Total % Time Since Times Max
Process Name Priority Time CPU Last Ran Ran Time
System Services-36 2 8 s 66 5 ms 3367 8 ms
Idle-3 1 682 ms 5 442 us 30830 188 us
Idle-1 226 2 s 14 287 us 15404 433 us
Hardware Mgmt-21 214 137 ms 1 886 ms 12 12 ms
Idle-0 226 794 ms 6 462 us 15338 564 us
Sessions & I/O-10 146 162 ms 1 67 ms 573 7 ms
TFTP-6 200 134 ms 1 6 ms 1818 508 us
