Campus Switching and Routing
How can I config dot1x with wire authentication on Aruba Switch S1500-48P
I have problem on Switch Aruba S1500-48P
Firmware 7.4.1.5
Can't config dot1x with wire to authentication
Re: How can I config dot1x with wire authentication on Aruba Switch S1500-48P
Thanks!  Herman Robers
I read it on ArubaOS 7.2 User guide document told me to generate certification CSR.
I generate some code so I need to copy that code on
-----BEGIN CERTIFICATE REQUEST-----
My code
-----END CERTIFICATE REQUEST-----
I need to copy this code and send some email to CA?
That all I want to do if I want to configuration dot1x?
Thanks :D
If you are using an external RADIUS server for the 802.1X and no captive portal redirects on the switch, you don't need a certificate on the switch.
For 802.1X you only need a certificate on the switch if you do EAP Termination. Recommended is to use an external RADIUS server for that.
