Campus Switching and Routing
Occasional Contributor I
How can I get my 2930M switches to report on connections?
I need to get a report from my switches on what is directly connected to them, i.e., Port #, device name, and device IP.
How can I do this?
Thank you
Re: How can I get my 2930M switches to report on connections?
show lldp info remote-device detail
This is good.
I guess I should have been more specific. I'm trying to see just the direct connections in a network monitoring software, querying the switches with an SNMP public string, and I'm getting a report of the entire Learned MAC Address Table.
Is there a way to just have SNMP just report on what is connected to the individual ports?
