Campus Switching and Routing
How do I reset an S1500 Switch without command line access?
[ Edited ]
I'm looking for a way to factory reset the S1500 switch (no LCD Gui). Something like a pin to hold down to reset or buttons to hold down to reset.
Any assistance is appreciated.
Aruba
Re: How do I reset an S1500 Switch without command line access?
cchojnack,
Unfortunately, you need to have console/CLI access to factory default it.
Best regards,
Madani
Hi There,
I am new to aruba hardware and I am facing a situation with my S1500 running 7.4.1.1 where in I try to boot the switch but it appears to complain about a file not being found and then hangs. Is there a CLI safe-mode from which to initiate a factory reset?
Thank you!
Please paste the output, so we can advise you.
Colin Joseph
Aruba Customer Engineering
