Campus Switching and Routing
How to Backup/Restore configuration of HP 1920s switch
Hi Everyone,
Help me find how to Backup configuration file on 1920s switch.
And how to store configuration file too.
Thank you.
Re: How to Backup/Restore configuration of HP 1920s switch
Im' looking for the same.
Did you find ?
I have written a short backup configuration file process on HPE 1920S Switch.  Please, follow the instructions written in the attached guide to backup configuration file on HPE 1920S Switch.
In addition, please, refer to the page 208 of HPE OfficeConnect 1920S 8G/24G/48G Switch Series Management and Configuration Guide below.
https://support.hpe.com/hpsc/doc/public/display?docId=a00003478en_us
Thank You,
Priyank Patel
Hi
Many thanks for your process guide.
But, to be sure, at the end, after uploading the file. We only have to reboot the switch ?
Yes, you must reboot the switch for configuration to take into effect.
Thank You,
Priyank Patel
