Campus Switching and Routing
Contributor II
How to assign ip address to a specific interface on Aruba Modular Layer 3 switch
Hello everyone,
I am trying to figure out if there is a way that I can assign an ip address to an interface port since my modular switches 5406Rzl2 are a layer 3 switch.
In cisco, "no switchport" command can assign ip address to interface. Do anyone know what is the equivalent command of "no switchport" command in Cisco L3 switches on Aruba L3 switches?
Kindly support.
Re: How to assign ip address to a specific interface on Aruba Modular Layer 3 switch
Hi, This is not possible. The 5400 / Aruba Switches don't support direct layer 3 interfaces. You can do this by creating a VLAN, assing the IP to the VLAN and offcourse assign interface to VLAN. You maybe also want to stop sending BPDU on these interface to have same function as layer 3 interfaces. I know it's a bit different that true layer 3 interface but it works perfect. Hope this will help you. Regards, Dobias
