Campus Switching and Routing
How to configure arubaOS authenthication fallback?
Hi.
any configuration to help me configure ArubaOS authnetication fallback or a guide to it. any feedback if someone has any experience with the configuration. any other workaround when clearpass is down?
Frequent Contributor I
Re: How to configure arubaOS authenthication fallback?
You mean TACACS with fallback to local?
JayBee
ACDX | ACCX| CCIE (RnS/SP,DC) | ACCP | ACMP | ACSA | ACMA | JNCIS | JNCIA
If the provided solution resolves your issue, please mark it as accepted solution to help others.
Well Im not sure if is TACACS. I need help to know if theres an option to configure a workaround on a customer that only have  a ClearPass server and goes down, and doesn't have any redundancy. I heard about the ArubaOS authenthication fallback.
- What is being authenticated?
-Do you have another radius server to fail to?
Your answers to those questions will determine what solutions are available to you.
