Campus Switching and Routing
How to delete an acceslist on a 5406 with running KB 16.02.0013?
How can I delete an accesslist with the irregular sign "." in the name?
Norbert Gietz
Re: How to delete an acceslist on a 5406 with running KB 16.02.0013?
Greetings!
From our initial testing, it does not appear that the CLI will allow you to remove the ACL as the invalid character validation check prevents the command from working.  We are investigating the issue in the lab; do you know what command was originally used to create the ACL with the "." in the name?
Matthew Fern | Technical Marketing Engineer, Wired Intelligent Edge
Aruba, a Hewlett Packard Enterprise Company
Greetings
If you configure the ACL in the VLAN context the invalid character validation check doesn't work and the ACL will be created.
Norbert Gietz
I'm filing a report with engineering on this particular issue so they can fix it; in the meantime, during your next maintenance window when you have an opportunity to reboot the switch, you can copy the startup configuration off the switch, rename or remove the offending ACLs, then copy the fixed configuration back onto the switch and reboot.
