Campus Switching and Routing
Frequent Contributor I
Instant vs RAP
I am considering what to choose for a remote campus where are about 50 access points needed. They are connected to the main site via vpn. At the main sitethere is an operational active-standby master pair with enough capacity to support the extra RAPs if needed.
Extra controllers won't be installed at the remote campus (budget wise).
Airwave is available.
Most of the traffic will be local, some traffic will go to the main campus, Internet breakout will be local.
Should I choose to use an Instant cluster solution or rather RAPs?
Is there a recommended maximum of RAPs, installed in one location, terminating on one central controller?
I always prefer controller-based actually, but in this case I'm not sure what to choose.
Br
Peter
Re: Instant vs RAP
Definitely not RAP. Generally 1-3 RAPs per location is recommended.
I'd recommend either a 7030 controller or Instant.
Tim Cappalli | Aruba Security
Re: Instant vs RAP
Hi Tim
Thx for your answer. May I ask why this is the recommendation? Is there some limitation or is it based on ipsec overhead and efficiency?
Br
Peter
Re: Instant vs RAP
It is more based on how many ipsec tunnels certain routers/firewalls can pass to/from the same location.  Some router/firewall hardware is limited to only a single ipsec connection.  Even some that can pass more also have a limit, but performance can also be a consideration.  It is a mixed bag.
In addition, like you said ipsec overhead and efficiency are always a consideration, as well.
Re: Instant vs RAP
Thx both!
