Campus Switching and Routing
Inter vlan routing in single ssid on aruba 7240 controller
We have configured aruba 7240 controller and assign the ap in group with AAA profile and ssid profile now we are able to connect to configured ssid with default vlan 1 but when we add another vlan (vlan 2) on ssid its not working  .ip routing is also enable on controller.so my question is why i am not able to ping to vlan 2 members????
Re: Inter vlan routing in single ssid on aruba 7240 controller
Adding another VLAN to the Virtual AP profile enables VLAN pooling, which load balances users into the VLANs entered into the Virtual AP profile VLAN field.  This has nothing to do with routing.  It only has to do with what VLAN a user ends up in initially.
You can see what VLAN a user is in either by the user's ip address or typing "show user-table verbose" on the commandline.
