Campus Switching and Routing
InterVlan Routing config
I have a network comprised of 2500, 2900 and Two core 5400.
Kindly share intervlan routing config. Any guidlines.
Contributor I
Re: InterVlan Routing config
Just create interface vlan and give the IP address and make sure ip routing is enabled
